ITV HD problem again!
gando
DREAMBOX dm800
uk
When I download Likra motor settings and select ITV HD all is OK.
When I use dreambox edit and make a new Favourite bouquet which includes ITV HD selecting it all I get is the sound of the programme and the radio desktop picture.
All I can do is download the Likra settings again deleting my new favourite bouquet.
Has anyone any idea whats going on
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
You have to edit your lamedb file in order to get ITV HD. It's very well documented in the forum. Just use the search function.
Dapperdan
Dreambox 800
Motorised dish
Hd Sky Box
United Kingdom
Open dreamboxedit,
Go to FTP Transfer files- Press recieve files from dreambox
You favorites should now be loaded,
leave dreamboxedit open, click on dreamboxedit and open another version of the same programme,
load likra moter settings into this second version,copy ITV HD from this version and paste it into your favorites (first version)
save then FTP send files to dreambox - reboot and it should work
gando
DREAMBOX dm800
uk
I have sorted my problem by taking a copy of the ITV HD lamedb file with the Likra settings - making my new bouquet with Dreamedit then replacing the ITV HD settings in the lamedb file like B16MCC suggested
I understand Dapperdans method and that will work also but why does the lamedb file get altered in the first place just with making a new bouquet ?
Anyway thanks to both
