Jaeger 1224 restoration
itchybag
1.1 stab motor with VU+ SOLO 4k, dm800, prof 7500
earth
started stripping down after soaking for a few days, think a grinder might be needed for the top plate bolts.
will these thread hammer out in any direction?1728820932471.jpg1728820932436.jpg
itchybag
earth
ive also removed the bottom nut from the swing bolt. is the only thing holding that inplace now corrosion?
the bottom plate came off easy also. the top plate though, the previous owner has already sheered 1 bolt off.
edit i just sheered the other 2 off so at least the top and bottom plates are off.
anto@
italy
take a hammer and hit it until it comes out then replace everything with a stainless steel bar and you will see that you will no longer have problems
as I had done in my modified 1224 EL
itchybag
earth
2 of the top plate bolts that sheered may come out with a bit of heat and some mole grips, the other is flush so will have to be drilled.
itchybag
earth
anyone got the measurements of the 3 threaded bars, i should have checked yesterday but didnt
Some of the bolts on the Jaeger 1224 are not conventional thread sizes, they are not metric. Others are metric.
I think the saddle clamp bolt and elevation axis pivot bolt are odd threads if original and not replaced.
The original U bolts are also an odd thread size unless replaced. The originals are more of a V than a U.
I binned the odd thread size ones and replaced them with stainless steel metric equivalents.
itchybag
earth
Toolstation have stainless m12 1000mm for £12. waiting for another fabricator to get back to me to see what they can do with the swing eyebolt. Asked if they can leave the eye undrilled as an option.
