Advice Needed Jaeger motor on 1.5
W
WHATAGOAL1
1.2 maxdigital, 1.8channelmaster, tm5402, tech1500, db520
Leic
I am going to replace 1.2 CM(jaeger motor) with 1.5 giilbertini will I be able to fabricate a plate for the 1.5 and just swap dish? or will the wind defeat the plan?
M
2.0m Precision
If it is a Jaeger 1224 motor it will be OK for a 1.5m dish. I have had a Precision 1.5m spun aluminium dish on a Jaeger 1224 motor for many years and it works perfectly with no damage to the motor.
Модератор
Yes, OK with 1.5m Gibby - I had it on as well.
