Links in posts need to be highlighted
On the new skin, at least on mobile, links in text aren't highlighted sufficiently like they are on the old skin, makes it easy to miss them:
Also note the skewed user image at the top.
Agreed.
Does Xenforo permit changes at this level of detail, @chris ?
Is the link still there but not highlighted? i.e., you can still click/tap on the link providing you know it's there? Or has the link been extinguished and that's why it's not highlighted?
The link is there and can be tapped to open.
A good example is in my reply above, whereby chris's User Name is a live link but you can barely tell (using the new skin, on Mobile and Desktop alike).
The link stands out in blue on both my laptop (IE11) and my mobile phone (browser not app).
chris
TalkTalk TV
Worksop UK
Does that look better ?
Nope, just the same for me! :-rofl2
(But then I didn't have a problem).
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Maybe a small point to add:
In a forum menu, there used to be a thick line separating the 'pinned down' threads, and the normal threads.
It always helped me a lot, to glance at the first 'normal' thread, that had new content.
Now, that line is hardly any thicker than the other lines separating the threads, so I have to look much more precise to find the first 'normal' thread.
Might I suggest to use a thicker line, or a line of another colour, between the pinned-down threads and the normal threads?
Greetz,
A33
I agree, a tiny colour difference or thicker line would help. Or you can revert to the previous skin - SatsUK Fixed or SatsUK Wide :)
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Well I am on SatsUK wide skin and I doubt further differentiation could be achieved, thick line present, pink background present
Yes it's the new default skin "SatsUK New" where the sticky/pinned threads blend in with the regular ones :)
a33
XSAT410
Rebox RE-9000
The Netherlands
Here's an example of what I mean.
SatsUK new: no pink, not a thick line.
Greetz,
A33
Topper
chris
TalkTalk TV
Worksop UK
I've just changed the background colours for sticky posts on the sats new skin, does this work better ?
