battenfan
- Sep 11, 2006
- 1.2m pf
- 60N 18E
I am speculating here but angles aren't that sharp as the signal fades at the edges and as the top is furtherest from the lnb, maybe Triax decided that the edge taper at the top isn't worth spending the extra dish material.View attachment 61982
With a openings angle of 60º of the BU (I dont know the real angle of that lnb) its in original position of the lnb , looking also to the lowest edge but there is a lot of overspil at the top .
Maybe its that the way the Triax should work .
http://www.qsl.net/n1bwt/chap4.pdf
