Lucuna Battery Connector
remlap
Wales
I am looking to buy a Lucuna Battery Connector like the one in the photo below.
Any suggestions on places to buy, and do I need a crimping tool to put the connector on or can it be soldered?
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
I normally get them from RS, but you need an account.
Maplin appear to sell them, but there's no photo on their web page.
The ones I use are crimp on, but you can bend over the tabs with small pliers, and stick some solder on for good measure.
Another place that sells ythem is Rapid Electronics-
2.54mm KK PCB Connectors
remlap
Wales
Thanks for the reply, sorry for taking so long to get back to you.
