I have a DB6600/DB6800 operation manual that I can photocopy at work if you're stuck. You can PM me your address. But be warned - it's not exactly a comprehensive document.
a big thanks to norm for helping me out and sending the user guide
anyway another quartion do i have to upgrade to use a cam or which cam the system accept without upgrading
please dont laugh at me lol i am really confused with the names of all sort of cam
dragon cam is it ok ? irdeto or via accces?
I expect the Dragon would be OK. I have a DB6800 and I have been using an Matrix Reloaded CAM for some time now. I currently have it running on Matrix Rev firmware. You can get MRs at exceptionally good prices at Spectrum at the moment, but whether that's the best option - well it depends on how much you have to spend for a start. Had you anything in mind viewing wise?
norm
i recieved your user guide you sent thanks a lot now i am looking to buy a cam which i decided to buy a MR somebody recommend dragon but i have no idea if it works on BEC
ROLFW maybe you can help please and should i to upgrade my system and how you do it?
I cant seem to get BECLink68 to connect to my BEC6600CI+. Im using a know good straight thru serial cable and my pc comport 1 is also been checked ok on other devices. I even tried com 2, just wont connect. I tried factory defaulting the receiver, but still wont show connect after selecting com1 in the software.
Any suggestions, thanks
Zener22
I HAVE TESTED BECLink68 ON WINDOWS XP BUT IT DOES NOT WORK.
IT ONLY WORK ON WINDOWS 95/98/ME. THATS WHY YOU CANT CONNECT TO THE PC (IF YOUR CABLE IS OK) YOU GET MESSAGE LIKE WRONG PARAMETER OR SOMTHING... BUT THAT IS NOT.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
