- May 7, 2007
- See signature
- Northants, Midlands UK & Lanzarote, Canary Islands
Nice result there Pete.
You would only need 2 Multi-Connects. Spacing at 4º on a 60cm dish would be the same as the spacing of 3º on an 80cm dish (look at my picture in post #27). Put the Multi-Connects on 1ºW and 9ºE. That way the less efficient LNBs will be nearer the centre, and the ones with a standard feedhorn further from the centre. Or the other option is just change the dish to a cheepo 80cm (less than 20€) and you won't need narrow LNBs.sonnetpete said:I've experimented with the 60cm tonight and got all those sats but I'm certain I'll need bullet nose LNB's as their spacing is 'cosy'
sonnetpete said:Set up the Triax bar on the TD88 this afternoon. Also made up a three LNB 'set' with a Smart (longer necked) LNB on a Triax plastic holder and an Alps LNB on either side, held by 40mm pipe clamps, extended from a pipe clamp secured on the centre LNB.
With the dish focused on 26°E I caught 28°-26°-23.5°. At one end of the bar I got 36°-39°-42° (with room to get 45°) and at the other end 16°-13°-9° (with room for 5°). It's encouraged me to have a rethink as if I can get more LNB's on the TD88 I may be able to position the 60cm dish and it's universal bar so that I can cover 5°E-0.8°W-5°W-30°W. That would be a bonus as I didn't really want a third seperate dish for 30°W but it looked inevitable. However, with the pipe clamps it looks possible. Time to invest €3.50 for another 5!!
