Advice Needed Motor Not Accurate
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
I have a SuperJack QARL 18+ used on a Laminas 180 (more info on my setup HERE ). It's powered by a MOTEK positioner.
The problem is that the motor is not accurate in stopping at the stored position. I often have to correct the position by a few pulses (from 2 to 10).
I have dismounted the motor but the gears seem fine and the movement also seems smooth.
I would have thought of slowing down the motor by lowering the voltage with resistors....
Does anyone have experience with this or any other suggestions?
Thanks for any suggestion!
Rose joint/end bearing bolts if you think the original polarmount bearings are OK?
Peyu75
Pace MSP980 Positioner x2szt
GI-S 980 2CR2CI HD PVR
Shovboxvitamin 5000HD
Lnb single Invacom SNF-031
Dish 2me 90E-43W Heavy Duty 36"
Orbitron mesh 3m
Laminas 1,8m 28E {1N 2F}
Poland
I have the same actuator, it's ok if you can connect it to a different positioner
