Advice Needed Motorised dish control by two receivers
Gladstones
Zone 2 Fixed at Astra 2
Gibertini XP 75 cm fixed at 30 west
Gibertini XP 1 meter motorised 53e to 27.5w
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Set up this manual switch it’s feel like well made and good value for money @ £9.81 free delivery by Amazon.
I checked the signal on both receivers on weak tps and glad to report no loss of signal.
It looks similar to the Philex switch I mentioned earlier.
Sometimes the easy solutions are the best. I have a box of the same type here, originally used for cable TV switching.
About £6 each.
About £6 each.
It is when the when the receivers are physically close together - but not so good when the "3-way cable junction" is out in the garden and it's dark & wet! :rolleyes::-rofl2
funtime261
Octagon SF8008, Vu+Duo2. ZGemma H9S, GT Combo, 1.1m offset USALS, inverto black ultra single, Gibertini OP125L , inverto black ultra single.
West Mids
Cheapest and easiest solution is what I use, which is a DiSEqC 1.0 switch in reverse. Up to four Receivers connected to LNB outputs and LNB connected to Receiver output. My Octagon SF8008, ZGemma H9S and Vu+ Duo2 are all able to control the same dish with this method. Works a treat. Only one at a time of course! :)
