Motorised Dish Setup with Technisat 65/70cm square dish.
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
I could be wrong ... just an thought... maybe the elevation restriction on the technisat bracket maybe a issue... As its only designed for Astra sats.
Which receiver are you using ??
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Noticed that when the motor is set to 0 on the receiver, its not exactly 0..
When the GotoZero or GotoRef(erence) command of the receiver doesn't bring you to zero, you can bring the motor to exactly zero, and do a motor reset. This reset would set the present motor position as the new zero.
Some receivers support the Reset command. But I believe also SG2100 type motors have a (sunk-in) button for reset. You could try that.
greetz,
A33
a33
XSAT410
Rebox RE-9000
The Netherlands
Not all, it seems:
Greetz,
A33
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
StrongSat FTA Reciever
80cm Dish + 45cm Dish via Disecq A/B.
England
Thanks, I'm gonna try that next time I'm up there... although today I replaced the cheap £3 LNB with an Inverto Ultra one... no signal improvement initially but a re-scan picked up more channels and some troublesome ones seem to work better.
