Multiswitch in Valencia region
joddle
Massanassa, Valencia, Spain
There have been a load of Vision, Fracarro and Triax multiswitches on ebay this week for very little money indeed so when I get back to the UK early next month I will attempt to get one to bring back. I also see the Invacom C120 quattros are only about £40 as well so may well buy one just in case of issues with the current quad which in any case is now about five or six years old.
Getting quite keen to try this all out - although it does mean a bit of cable rerouting etc. I assume the multiswitch should be as close to the LNB as possible so for me that would be a cable run of about 6 or so metres so I can put it in the dry and access a power point.
Still can't see the need for more than one feed per room apart from in our lounge where the PVR needs two.
S
Steve Steve
I might be worth considering a 9 in / 8 or 12 output multiswitch...so you have the option in the future to add a second sattelite position Eg 19,2.......it will also work fine with non Diseqc Freesat and Sky boxes ...as long as you connect the 28,2 cables HL,HH, VL, VH to inputs 1......on the multiswitch.....
Also....If you loop through on your Humax HDR with one cable input .....it is possible to record 2 Channels with one cable input....but only .....If the channels are on the same H or V polarity....that is......
A nonymous
Its quite common on bigger systems for the dish to be anything upto 20-30m away from the switch (headend). Most other branded switches only allow you to attenuate the signal. If you go for the Vision switch you can amplify the signal without the need to use a separate amplifier so you can have a bit more leeway regarding how far away the dish can be.
Certain Vision switches can also be remote powered so its not necessary for you to have a power point right next to the switch. You use a remote psu and link the switch and psu by using a length of coax. In Europe Vision equipment is branded as Terra so you may be able to get one where you are.
Nano
Future proofing. For me 4 in the living room isn't enough.
satelliteman
I like the v5/v9, plenty control at each switch location.
Sent from my Galaxy S4 GT-I9505 using Tapatalk Pro
NeoPhyTe
1.3m Famaval dish
Inverto Black Ultra Quattro 0.2 - 28.2°E
_______________
80cm dish
Inverto Black Premium Quattro - 19.2°E -V/L
Invacom 0.3 Quattro - 13.0°E -V/H, H/L, H/H
_______________
Inverto Unicable Multiswitch IDLP-USS2OO
Albacete, Spain
The config I'm using now is a multiswitch Unicable with 2sat. Only 1 cable to my home, 3 decoders inside (different sats and channels), strong signal (no loses with it in Albacete near valencia and 1.3m famaval) as the multiswitch is around 3m from dish, and it has a built-in amplifier. Don't know if it's compatible with quad because I have Inverto black ultra quattro and I didn't test other.
It's here: http://www.inverto.tv/products/product.php?id=161
It has 2 satellites, it cost me around 160€, sure with 1 sat is cheaper than it.
PD: The 1 sat model: http://www.inverto.tv/products/product.php?id=142
the only requirement is that your decoder has to be unicable compatible (Enigma based ones are)
Regards
Regards
Where did you buy that?
NeoPhyTe
1.3m Famaval dish
_______________
80cm dish
_______________
Albacete, Spain
BLUEPLATINUM
Maspalomas, Gran Canaria
I am using a OPTICUM OMS 5/8P and am very pleased with it.
joddle
All the info here is all very interesting - I was hoping I could get a switch with remote power as I don't have power socket anywhere near the dish - I read on this thread some have coax power feed - but which ones? - so far not seen any which can run from a feed up the cables. And if so are they any good?
briangw
Los Lobos, Almeria
Humax HDR1000
Samsung 40" TV
FS Passion+160Gb
Samsung 22" TV
Humax Foxsat
Hannspree 22" HDMI
1.8m Prodelin offset
Triax Cascade System
with 19 Apartments
Los Lobos, SE Spain (Lat: 37.3087° Long: -1.7647°)
The Triax TMPR range can be receiver powered. Havent used them myself, only the TMM cascade switches, which work very well for me and seem well built.
A nonymous
The Vision V5 and V9 range of Vision switches allow you to remotely power them. They have a separate input for the power which utilises coax and f connectors as the medium to transmit the power through.
I have also used some Televes switches which are also remote powered but quite frankly i thought they were s**te due to the amount of signal attenuation through them.
As for receiver powered switches there is as already mentioned the Triax TMPR switch you can use. There is also the Vision Phantom switch and also the Fracarro SWI516DC & SWI508DC switches. The Triax TMPR switch allows attenuation of any signal input but does not amplify it.
The Vision Phantom and fracarro switches are self setting which usually just means attenuation of the signal. Some of these receiver powered switches can also be problematic with certain models of Sky receiver.
In all honesty if you have issues of signal strength i would just go for the Vision V5 or V9 switch as at least you have a small amount of signal amplification. You also have incremental output strengths down the length of the switch again giving you a lot more control over other switches that have the same output strength on every port.
It just means you have to run one length of coax between the psu and the switch which is a small price to pay for such a great performing switch.
This old thread may also help.
http://www.satellites.co.uk/forums/threads/advice-on-fracarro-swi-6908-multi-switch.152159/
Nano
