Multivision Problem
picop2es
Istanbul 05 -Rafazaman
DB7020 ,Gemini 2.9 ,Gbox ,Broadband (Lol)
Motorised >30w
chester
Just thought i would check to see if anyone is having problems with Multivision tonight?
My TPS Channels are ok but Multivision has a very high BER Rating and wont clear.
Johndoe
none
Us
I have the same problem!
The Multivision channels are on a weak transponder and will be one of the first to notice any problems due to weather, dish alignment etc.
The Dreambox dosnt have a particulaly sensitive tuner if i connect my 8year old Nokia 9600 to the same dish it locks fine!
Try checking dish allignment, cabling etc.
Johndoe
none
Us
just a further note
I niticed you are using a 1.2 meter dish, the alignment on big dishes is much more critical than a smaller one (not sure why, something to do with physics and i did metalwork at school!)
picop2es
Motorised >30w
chester
Thanks J
The problem seems to have cleared up , but i will keep an eye on it
mhku
TM Nano ~ sg2100
Midlands
Was it raining or windy, or both?
