My go at WXSAT
pontiend
Contibruter
south yorkshire
I may have found the problem.The RTL dongle may be faulty.I have swoped it with the RTL dongle that I use with VRS it does not work with Dump 1090.I will test it the next time that I can catch NOAA 15.
pontiend
Contibruter
south yorkshire
This mornings scan of NOAA 15 is not a good one .Although the satellite was well over in the west,perhaps the trees were interfering with the signal. I will see what the scans are like this evening.18.26 hr Mel 27 E Long16 E and 20.02 hr Mel 65 W Long 6 W
EDIT.
The 11:22 scan of NOAA 19 at Mell 48 W Long 11 W.Nothing wrong with that one.The trees do not interfere with it
EDIT.
Do you want to try a little used dongle for testing (oooerrr) ?
pontiend
Contibruter
south yorkshire
I missed the 18:26 scan still enjoying my can of Bud down the garden :).Waiting for the 20:02 pass.The path is Mel 65 W Long 6 W the trees should not interfer with that pass.I do have three of these dongles one seems to be a dud.I will keep in mind your offer of trying another dongle.
pontiend
Contibruter
south yorkshire
Nope this one is worse.Not even a rendered picture this time.Just the original scan.I There are not many passes of NOAA 15 it will take a while to sort this.
pontiend
Contibruter
south yorkshire
I finaly got my brain into gear and googled NOAA15 problem..
The satellite is having problems with its scanning motor.
Panic over.:D
@pontiend The guys on the facebook APT group Im in are reporting major problems with NOAA15 passes. I suspect the old gal is broken again.
pontiend
Contibruter
south yorkshire
I have a look at NOAA 15 every few days wondering if they will get it going again.Earlier tonight I got a good scan.Thinking that I must have got something wrong I waited for the 19:48 pass to confirm that I was not imagining things.The second scan was good it looks like the problem may have been sorted.
pontiend
Contibruter
south yorkshire
I give in .The 19:22 pass looks alright,the only thing altered is the Mel and Long settings.
