OldBen
Mad Scientist
- Jul 29, 2005
- Age
- 47
- Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch. VU+ Duo. Emitor Satlook Lite meter.(Retired: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB
- UK
Ok, I am still confused. I read through the first 4 pages and threads that look relevant, and did a bit of search time, but my brain still hurts on how this is supposed to work.
With a bit of luck and a prevailing wind should be moving house next year, its new build so have option of specifying some additional cable runs (at wallet-busting prices no doubt) over standard lounge + bed 1 feeds.
At the moment where we are we have standard UHF amp in loft, with TV/FM fed into that, and sent out to 3 rooms with 2 additional feeds to a PC in the garage that records freeview. Simple stuff all coax/VHF/UHF. Also have sat receiver & motorised dish, with straight feed from dish to receiver in lounge. Single LNB. Easy. No Sky.
Thing is Berkshire is last to get Freeview HD in 2012, so when we move will get new main TV with Freesat integrated, and possibly freesat dual PVR in lounge as well. This means I want to work out how to potentially split the sat feed to 4-6 locations (lounge TV + poss dual PVR, kitchen, two bedrooms - kitchen/bedrooms to follow later when funds allow).
This is where my head hurts, as I understand you basically have two modes for LNB, Horizontal and Vertical, so you have to have multi-LNB's - seems logical. Can you however have two LNBS (from a quad or Octo obviously for future proof) into some sort of switch with one permanently horiz one vertical and each TV/freesat receiver would be switched to each one as required? Or if you had 4x Freesat TV/receivers for example do you need a quad LNB and 4 input device and somehow the switch lets each receiver pick a free LNB? This is the bit that really boggles my noggin?
If someone could explain what would be needed in this scenario would really help me out understanding what I might need :-worship
I realise I could dispense with any sort of distribution and put an additional cable drop to each location from the dish, but I am working on the assumption each run will cost me dearly from the builder, and trying to understand if there is a way to do this with single run to most of the points (more spare drops to lounge obviously for flexibility) with relevant filter/outlet plates of course.
Then to add to the confusion, I also want to use the existing technmate receiver on 1W for Czech TV for family & visiting dignitaries on the wife's side. 1W is too far over from 28.2E for multi-lnb bracket, so will probably look at second dish for this potentially (using sky minidish for Astra/Freesat). Is there an easy way to switch this into a system with DiSEQc or multiplexing somehow into the feed to all rooms? (so I could have this receiver in lounge, or in a bedroom?) or am I best to stick to dedicated feed for this, and some sort of RF loopback to distribution with magic eye to view in other rooms? (I understand from other posts there are boxes available now for non-sky receivers that come with IR blaster for receiver end and use defacto irlink setup and viewing TV end?).
It seems something like a loftbox does what is required if it was a straighforward sky to all rooms from receiver box in lounge situation, but as I want freesat in each room, so each room needs an LNB feed essentially, I need something more industrial from Vision or Fracarro that has "4 sat inputs", just not clear on how this works, and if I just need Astra horiz and vertical do I only need 2, or if I have 4 freesat tuners do I need 4 inputs from a quad and each set effectivly gets switched to an LNB? Just confused how this works if its 4 sat in and 8 outputs?
Help!
Help!
