OldBen
Mad Scientist
- Jul 29, 2005
- Age
- 47
- Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch. VU+ Duo. Emitor Satlook Lite meter.(Retired: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB
- UK
Yes its either 5 core + Earth Webro, or 4 core which I think is also Webro wrapped in a sleeve. The 5 core has a white for terrestrial in addition to the 4 quattro colour coded cores, and a standard earth. They are both WF100 9mm cables I think, just sleeved in a plastic wrap.
I can see the benefit of the colour coding, but worried the big OD may be a pain to work down dish arm and into house. Plus I need 3x WF100 for TV, FM and DAB as well, so plenty of holes!
A well known online retailer seems to do the 4 core by the meter at £2.49/m so as I will only need 4-5 meters I expect it may be worth a punt for a tenner, I can always just use colour coded multiple runs of WF100 as you did if not.
Still waiting for house to be built, going by later today, they may have most of roof on which will be good if the predicted snow is coming!
