Can't remember which type of file both of those images use, but it will either be tar.gz, or tar.bz2, so if you find a copy of the emus in both formats and upload it to your temp directory, then you should be able to uplad them using the blue button, under manual install.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
