Help Required Need help to programme an iSmart Satellite reciever
Kevin c Daley
I have a four foot 2lnb disk set-up at my home
Jamaica
Hello,
I am new to the disk network and need some help with configuring my iSmart Satelite reciever to be able to pick up channels from two satelite (two LNB on one disk). The box details are as below:
iSmart X10 Turbo 8PSK "NEWEST 2015 VERSION" High Definition PVR Receiver (Full HD) , WiFi Included & JB200 Installed , External IR , HDMI Cable & AV C
Mickha
North West
If you have two separate LNB's then you probably have a Disecq switch, so the two cables, from your two LNB's, then lead to one cable going to your receiver.
If this is the case then try going into the receivers menu and selecting Diseqc 1.0, or Diseqc A,B,C,D option, then manually scanning in some channels.
BlindFaith
TBS 5925
Kevin c Daley
Jamaica
OK, I'll give it a try
