ruasonid
- Aug 9, 2019
- Age
- 62
- VU+ Solo 2, 90cm dish, Technomate TM2600
- Midlands
I purchased a Technomate TM2600 along with a VU+ Solo2 and 90cm dish in spring 2015. The dish is installed below guttering at roof level in a southerly aspect - it is not exposed. The equipment has had what I would describe as light use. Perhaps a few times a month in terms of dish movements. The motor recently stopped responding to commands. I found a green LED on at the motor and tried a reset using a bent paper clip. I was able to get the motor to move a little Eastward around 50 degrees but it moves no longer in any direction. I've re-installed Blackhole 3.0.9 just to ensure there were no software issues. I'm guessing the tuner is OK.
I'm thinking the motor might be at fault and if that is the case disappointed in consideration of the little service it has given.
I need a motor that is at least as quiet as the TM2600 (preferably quieter). What would be my best options in terms of replacing the motor?
