Advice Needed OCTAGON SF4008
Ghostleader
Glasgow,ish!
That's me added an internal hard disk to the Octagon now. Screws and connection cables were supplied with the receiver as well as an external data cable for the 2 back usb ports. Recording is working. Still to try is to record a 4.2.2 channel and play with Nvidia Shield TV box. Got to find the feed first with the Dr HD blind search, then input the details into the Octagon and hope it has not disappeared before I hit the record button!
The satellite search screen really needs a signal indicator. I miss that badly. It also needs a transponder delete button. Is all very well downloading a ready made transponder list but when it covers the different footprints a satellite covers it means the satellite search has to check a lot of transponders with no signal slowing down the search process.
Using a couple of external satellite editors and sending the amended details back the receiver was unsuccessful and ended up with a non working channel list. Backing up your settings is soooo important! Editing Satellites.xml and then rebooting the receiver worked.
I'm learning, but patience, I am finding, is absolutely essential with this kind of receiver.
Right Andy, Spill, What make & model HDD did you put into your receiver mate? As many of the guys know having read my thread I'm on the hunt for a 2.5 inch HDD for putting in a new sat receiver, I was looking at the Mutant 4k but this Octagon has me interested also.
maxi_power
120cm motorised dishes
PT
For blindscan linux satellite receivers simply are not an option.
Depends on the receivers, i have an AzboxME and captures well feeds 4:2:0/4:2:2 with very low symbol rate or highs.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
It's an M4-CT126M4SSD2 . At 126gb it's not very big if you want to do a lot of recording. It was left over when I upgraded my computer C drive to a Samsung 250gb sd. I would never go back to a traditional mechanical drive after experiencing a solid state hard drive. They are so fast. They were very expensive when they first came out hence I had such a small main drive. Only essential programme and the system files were kept on the main drive. It was a bit tight. Doubling the capacity of the C drive to 250gb was just right.
Anyway, using an ssd on the Octagon works well with no delays and no mechanical bits to get warm inside the case. If I need more capacity I am satisfied a larger ssd will do the job well.
Ghostleader
Glasgow,ish!
Cheers mate, anything that reduces internal heat is a smart move.[emoji106] [emoji4]
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
I can now report that recording 4.2.2 using the Octagon I can access the recording with the Nvidia Shield while it is still recording any playback is perfect for picture and sound.... Success at last!
michalmichal
Ariva 120
Technomate
nbox turborecorder
Dish 100
Dish 80
Poland
So Octagon is recording and Nvidia shield tv is playing this recording at the same time ? How do you connect octagon and nvidia shield tv ?
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Es file explorer on Shield to locate video file and then launch with VLC video player. I also managed to use the same technique to view on my mobile phone.
Tururu
Assembled with recycled parts
Recycled as the owner.
Normally on the receivers with Enigma2, you can stream a channel to the PC and using videolang you can watch a channel in 4:2:2 live and more.
Videolang has no problems, it also worth MPC-HC
It is also not a problem to play the recording of a channel when it is still being recorded.
This trick also allows to play a UHD channel on the PC/Computer with 1Gbs network, minimum i5 and a good video card (clear monitor resolution)using a normal recertor HD like VU+DUO2 and others with 1Gbs network.
This "trick" allowed to use an SD channel receiver ((DVB-S ==> DB500S/DB7020Si) to watch broadcast channels in HD (2004-2008).
Normalmente en los receptores con Enigma2, puedes hacer streaming de un canal al PC y utilizando videolang puedes ver un canal en 4:2:2 en directo y mas.
Videolang no tiene problemas, tambien vale MPC-HC
Tampoco es problema reproducir la grabacion de un canal cuando todavia se esta grabando.
Este truco permite tambien reproducir un canal UHD en el PC/ordenador con red 1Gbs, minimo i5 y una buena tarjeta de video (resolucion del monitor claro) usando un recertor normal HD como el VU+DUO2 y otros con red 1Gbs.
Este "truco" permitia usar un receptor de canales SD (DVB-S ==> DB500S/DB7020Si) para ver canales emitiendo en HD (2004-2008).
To the mobile phone according to power of the video card and always better by wifi network of house/internal (normal streaming or transcode)..........................................
Al telefono movil segun potencia de la tarjeta de video y siempre mejor por wifi red de casa/interna (streaming normal ó transcode).
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Where's the blind scan then ?! Yawn zzzzzz :(
maxi_power
PT
It seems that blindscan is not a priority for the octagon developers, but it does not cost anything presses them...
http://www.opena.tv/octagon-sf4008-4k-linux-e2/32771-blidscan-sf-4008-a.html']Blindscan SF 4008
Well very disappointing re the Blind Scan 1st mentioned here over 10 months ago but still not available receiver released in 2016 :eek:
Maybe Octagon are saving this feature for it's next UHD release like they did with the HD receiver SX88 ?
molhopicante
Dreambox 800SE
Portugal
If they do that, I will never buy brand Octagon again...
