OCTAGON SX88 H.265 HEVC HD
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
I didn't want to be rude.
All the project is good and I appreciate it, but I am only tired to have recording problems.
Sorry.
Let's Hope for the best.
Ciao
Sorry.
Ciao
Recording are OK with me using an external HDD..
Pierangelo
Italy
Only for the records, recording is not working only on French multistream HD ( France 3, Yes) and t2-mi Russian TV, the same for Subs.
All other channels are perfect, A+!
Ciao
Ciao
Ahh, I see. Not tried to record anything off multistream
stephan94
Bavaria
Hallo
there is recording big problem with in these cases there (Octagon already knows it)
first T2MI: it does not work, the receiver jams.
on the other hand, the recording of MIS with several streams,
the picture on the screen jams but you can go out with the remote control,
but if you want to read recording the receiver also jams,
anyway data are not full.
stephan94
Pierangelo
Italy
@stephan94
Dear, considering your possibility to talk with them, could you ask
to add access to usb through FTP.
Pierangelo
stephan94
Bavaria
I ask if it is possible.;)
At the moment there is holiday in Korea, we have to wait until after October 10 for the answer. :(
Pierangelo
Italy
Sorry , i can't find any more Cas menu ( the complete one, not only 0000)
stephan94
Bavaria
It was probably another entrance for U2C Denys
Everything is not 100% similar to the menu.
stephan94
Bavaria
Again a reception sensitivity test, but this time in Band C.
57 ° East is hard to receive with a 1.20m antenna in northern Bavaria.
The card TBS 6983 locks the signal with -10dB, indicating a very limited signal.
Octagon SF4008 (the most sensitive receiver that I know) also locks the signal but the picture is not good
The SX88 also managed to lock the signal, but with an image that sometimes disappears and that is bad,
but it still happens to read this frequency, indicating that it is also very sensitive.57 ost Cband TBS6983.jpg 57 ost sx88-vert.jpg
MCelliotG
Thessaloniki, Greece
It's an exceptional tuner, I cannot even imagine the newer RT270 revision (used in Zgemma H7 and as an extra for HD51) could possibly perform!
Pierangelo
Italy
Dear,
if you kindly can ask them to update $ about 57 east (C band) MTN package... I am going to test it for you all with my 150 cm, I get 35% of signal, still yellow, but sufficient I hope to watch.
ciao
Ps tchad tv is ok for me, but sadly no french only in arabic......
stephan94
Bavaria
what ist the problem with MTN package ?
Pierangelo
Italy
I don't know if keys are available and auto-updating. No Image with Yellow signal at 35%.
stephan94
Bavaria
I feared this kind of question.
I can only repeat
I'm not talking about everything related to encryption.
campag5242
Dishes: TD110, TD88
Receivers: SF4008, SX88, Samsung TV
NW UK
Hi stephan94. I'm hitting the 400 TP limit on Eutelsat 10E fairly quickly with my small dish picking up 9E too.
Can that 400 limit be raised again, or do you know if a settings editor might be planned?
stephan94
Bavaria
400 Transponders ???
this is not possible, even with 9 degrees East.
satellites that are most transponders (Astra or Hot Bird) have up to 120 transponders, the two sets that makes 240.
Must occasionally delete Feeds with the SX88 has a BlindScan this is the advantage before each BlindScan can erase everything.
samoloko
1.8 PFA
EU
but it still happens to read this frequency, indicating that it is also very sensitive.View attachment 110710 View attachment 110711
Stephan,
great post, thank you
new dreamboxes use similar type sat tuners - si 216xx
did you happen to compare sf4008 tuner sensitivity with DM820, DM7080
stephan94
Bavaria
I can not compare because I do not have a Dreambox (DM820 and DM7080)
sorry
