Octagon SX89
Whilst waiting for SWMBO to cook the turkey, I was minded to look again at the "progress" on the above, and here is the Google translate version of the Octagon webpage on this Rx
PS: bit by bit due to Google translate character limits!
Slight surprise: I thought earlier info said that it has USB3, not USB2, ports?
"OCTAGON SX89 HD - The Full HD class redefined!
"OCTAGON SX89 HD H.265 S2 + IP Receiver Dual Core (2x1200MHz) ARM Cortex-A7 CPU Multimedia Multistream Black"
With the new SX89 HD H.265 S2 + IP you get a multimedia box with Linux operating system, dual-core 32-bit CPU and razor-sharp resolution. Now also with HDMI CEC support. The box is characterized by powerful hardware and a wide range of entertainment options. It supports all common functions that a modern multimedia box must have.
Hardware: the technology under the hood of the OCTAGON SX89 HD H.265 S2 + IP
The machine room of the SX89 HD contains the most modern hardware with which almost all your multimedia requirements can be met. A Hisilicon 32 bit processor and a multi-core graphics processor are installed. This equipment not only ensures smooth playback of your multimedia content, but also fast boot times and fast navigation within the multilingual menus.
Full HD resolution H.265 HEC 1080P
With the OCTAGON SX89 HD H.265 S2 + IP Receiver you can enjoy your content in razor-sharp FHD resolution at 60 frames per second with 1920 x 1080 pixels. In addition, the SX89 HD H.265 IP E2TV offers a multiroom TV client system from Enigma2 devices. The SX89 HD decodes the content in the HEVC / H.265 standard, which among other things helps to conserve your bandwidth. Standards such as The OCTAGON SX889 HD H.265 IP supports H.264 and AVS as well as almost all video, audio and image formats.
Entertainment functions and other features of the small S2 + multimedia box
The OCTAGON SX89 comes from the factory with the extremely popular and easy-to-use Linux operating system. This allows you to benefit from the possibility of being able to continuously expand the entertainment offer. Numerous free apps such as YouTube, media libraries and numerous popular media players are available for this purpose. There are almost no limits to the enjoyment of entertainment and you will get your money's worth as a multimedia, series or film fan!
Interface diversity and connectivity
OCTAGON has given the SX89 HD H.265 S2 + IP the most common interfaces and thus ensured a high level of connectivity for the multimedia box. There are two USB ports on both sides of the S2 + multimedia box. On the back of the SX89 HD H.265 S2 + IP you will also find an HDMI 1.4b connection, an S / PDIF interface, an Ethernet LAN connection and a DVB-S2 satellite tuner. An integrated card reader and a connection for the included external IR receiver are also attached. Full HD resolution H.265 HEC 1080P
Key Features:
- ARM Cortex-A7 processor
- Hisilicon Hi3716MV430C Huawei
- Quad Core 32-Bit (2x 1.2GHz) 3000 DMIPS
- Multi-core high performance GPU
- 128MB flash memory
- RAM 256MB DDR3
- Fast boot time of 15 seconds
- LAN Ethernet (100Mbps)
- 4-digit 7-segment display
- Card reader + hardware BlindScan (blind search)
- DVB-S2 tuner + multistream support
- HDMI 1.4b - HDCP1.4
- 2 x USB 2.0
- Infrared receiver for hidden assembly
- HDMI CEC support
- E2 (Enigma2) Setting Support
- Learning multifunction remote control
Features & functions:
- Linux OS operating system
- Resolution: FHD 1080P H.265 HEVC (1920 x 1080)
- Custom extensions and logo support
- Internet radio & YouTube
- Media libraries of the public broadcasters
- 2 x USB 2.0 ports
- SatLess multiroom TV client system for Enigma2 receivers
- User-friendly OSD surface
- WebIF & FTP access
- card reader
- Recording & TimeShift
- Network 10 / 100Mbit LAN
- WiFi (WLAN) + 3GB modem support via USB ports
- DLNA player (DMS, DMR) & built-in media player
- Playback of M3U playlists
- iOS and Android app (.apk) remote control & web browser (WebIF)
- Unicable & FastScan support
- DiSEqC 1.0, 1.1, 1.2 and USALS support
- EPG - Electronic Program Guide
- High resolution OSD UI user interface
- 4x programmable buttons on the remote control
- Direct buttons for WebTV, VOD and YouTube
- Subtitles & Teletext (Teletext) support
- 0.5W standby
- Dimensions (LxDxH) 142mm x 93mm x 24mm
Front:
- IR sensor (infrared receiver)
Device top:
- LED display (red / blue)
Back:
- DVB-S2 tuner LNB input
- Digital audio socket (S / PDIF)
- AV - audio video socket - jack to RCA
- HDMI 1.4b output
- Network 10 / 100Mbit connection
- DC-12V power supply
Page (right):
- SX89 HD H.265 S2 + IP
- CA card reader
Side (left):
- 2 x USB 2.0 ports
- LED / IR (external display or IR infrared receiver) connection
Scope of delivery:
- OCTAGON SX89 HD H.265 S2 + IP receiver
- Learning remote control
- Power supply adapter
- HDMI cable
- IR infrared receiver
- Operating instructions (German & English)
- 2 x batteries
Tuner & Demodulator:
- RDA5815m & S2 GX1133
Others:
- Dimensions (LxDxH) 142 x 93 x 24 mm
- EAN barcode 4260189996563
- Power adapter (power supply) DC12V-1.5A
- PU 20 pieces - RRP 67.90 euros"
Edited:
Only retailers found so far seem to be in Germany:
- satking.de
- hm-sat-shop
Both selling at 67.90 Euros + shipping
For another £25 you could get a UHD in the form of the SF8008 mini.
The inference was that it would be the same as an SX88 4K but without the 4K. No USB 3 is a poor decision:N
Probably because USB2 can handle the recording/replay streams for 1080 video - and it was slightly cheaper to implement. A disappointment nevertheless.
