Old remote control
aramiz
SFT-2000E
DM-5620
SkyStar 1
Portugal
I'm a happy owner of a DM5620, but the remote is getting old (keys are getting stuck when pressed or don't respond), wich leaves me with 2 choices:
a) buy a new remote - been googling around but didn't find the remote seems it's out of production, so I ask if anyone knows of compatible remotes (DM500 or DM7000)? :confused
:cool: try to open the remote and clean it - would apreciate any knowledge about this manoeuvre (since there are no screws, I guess the remote is incased and before unwillingly destroying it if anyone knows how to open it, that would be great!) :confused
Thanks in advance
HB13DISH
Retired Mod
Middle East - Israel
I don't know how does your remote looks like, but you can check this page and see if it looks like the one for 7000S.
Or contact the website
_http://www.satstore.co.uk/digirec.htm
If you can't find it, then you might like to use a universal remote instead. They are quite cheap, but you have to do the learning keys by yourself.
In the meantime, don't open the remote until you have a solution one way or the other.
welsh clarky
dreambox 5620s, 28e 19e 13e,
wales gwent
i can confirm that the dm500 remote will NOT work for me on dm5620 ive tested this the dm500 remote has no dream button on the remote dm5620 pic of remote unless iam doing something wrong
[fieldset=Admin]please upload images to our server[/fieldset]
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Hi
1) Read the idiot guide, there is an excellent description about opening up a 5620 remote.
2) I am using one of those 27 Euro replacement remotes bought on ebay. The "sound off" and "TV" buttons are swapped, but once you know that it is not a problem. Also, the "exit" button is now the most lower right button. Me and the kids are using the new one without a problem, once you get used to it no problem.
welsh clarky
wales gwent
hi...... t_g is the remote you are using for your dm5620 a dm500 or the dm7020 remote
T_G
Hi
I think it is one like this, but not sure. The price was something in the region, and the picture looks like the one I got
_ttp://cgi.ebay.de/Fernbedienung-Dreambox-DM-7000-S-7020-S-7025-S-7020-Si_W0QQitemZ380174966638QQcmdZViewItemQQptZOriginalfernbedienungen?hash=item5884319f6e
They are pretty sturdy as well, it survived it being smashed onto the floor in anger. The batt. lid shattered, but the remote still lives. And the glued cover is a reminder to everyone not to get me upset, or else the remote gets it :)
You might want to investigate this one, it's a shop in Germany selling these remotes. They are quite cheap, so might be worth a punt
_ttp://www.srt-versand.de/fernbedienung-fuer-dreambox-5er-und-7er-serie.html?campaign=preisroboter
welsh clarky
wales gwent
cheers looks the same and good price many thanks T_G
totalacedude
Edit. 5620 several 500,'s (clones) vu duo blackhole pc server 95cms motorised dish blah blahh
crewe
hi all...
is it just not easyier to use a 800 remote control (7000 series)
and just change the settings in the menu to '70xx remote' settings...
i had a moment of drunkeness and lost original remote just got a £10 one off ebay :)
