Old type remote and Sky HD box
pajo100
1.2 /1.8 Channel Master fully 36v motorised 58west to 42east Pace MSS500 Positioner
,Technomate 6900 Super HD ,Humax 8100PVR oh and a Amstrad Sky+ digibox.
Ireland
Can a old type sky remote be made to operate a new Sky + hd box guyz??
A nonymous
I know it doesn't work the otherway round so i should imagine not.
I got my hands on one of the Sky+ HD Chrome remotes only to find it does not operate my Sky+ SD box, so i should imagine they use different command codes/frequencies.
:-beer
Nano
You could change an old Sky remote to operate a limited set of the Sky+ commands - Ive done it. However it was only two or three of the commands that worked.
I rather doubt it would work with the newer HD boxes.
CROSSBONES
S.Wales
All Sky remotes after version 4 can be reprogrammed to work any Sky box
pajo100
Ireland
he did say any SKY box not Sky + or HD!!
davemurgtroyd
Oxford
Oxford
timo_w2s said:
Cool, how?
For any Sky remote version 4 or later
Press tv
Press and hold Select and i on HD remotes OR Select and Yellow on standard and Sky+ remotes until red led on remote flashes twice
Press 0 for standard sky, 1 for Sky+ (or 2 for sky HD only on HD remotes - but standard and Sky+ remotes will control HD boxes in Sky+ mode)
Press select - red led should flash twice
Press Sky
pajo100
Ireland
Does not work on skyplus remote version 6 for HD box.
davemurgtroyd
Oxford
Oxford
Both my HD remotes are version 8 and select and i work fine. Someone on another forum suggests that select and yellow works on earlier HD remotes
pajo100
Ireland
Mine is a version 6 for Skyplus and will not work on the HD box.
davemurgtroyd
Oxford
Oxford
Both my version 6 and version 8 Sky+ remotes control my HD boxes without reprogramming. The only remotes I have come across that cannot do this are non-genuine clones.
boardtc
Sky+hd box
Ireland
I got a spare sky+ remote version 8 (the original went missing a few weeks back), I have reset it no problem using the instructions for hd remote above (setup+i works, so I select #2 when resetting, have tried others too).
But it will not work with my sky+hd box. My understanding is that it should but unsure.
Any advice appreciated!
davemurgtroyd
Oxford
Oxford
Is it a Sky+ (grey plastic) or Sky HD+ (silver or black plastic) remote? If it is a Sky+ then "2" will NOT work - use "1" and it should control both Sky+ and Sky HD boxes.
boardtc
Sky+hd box
Ireland
Thanks. It says sky+ version 8. It's 2 tone colour, grey font, black bottom half back. I tried again with setting it to 1, but box does not respond to controls after being set.
^^^^ :Y
I suspect the subject is no longer current as the previous Posts were from 2015 and the original query dates from 2010 :)
