pc satellite
It would appear that your socket is connected to an Astra 28.2E system, Eurobird is co-located. There isn't much exciting TV on this satellite, unless yoiu have a Sky Digibox and a subscription. You really need to get a dish installed on your balcony to access the more interesting satellites, 19E and 13E would be a good start.
Before you start with a new dish though, you need to get your version of MyTheatre producing the goods. You probably need to add some transponders to pick up some of the channesl on 28.2 East, so if you look at LYNGSAT as already mentioned, find the transponder information and then add it to the transponder list in MT, then do a scan of that transponder. You won't see ITV2, it is encrypted at the moment.
See two screen shots for settings and added new transponder for BBC London etc.
AMD Athlon 2.80X2 64 7850 Black Edition Dual-Core Processor
Jetway RS780-SB700
Chipset- AMD 780G Rev.00
MSI Nvidia 9400GT 1GB
Prof Revolution DVB-S2 USB 7500
India
how can i scan channels provided by DIGI CABLE through DVB-S2 card without using dish.
pgh13
Midlands UK
Welcome, but talk of cable is not permitted here. Also, this is a very old thread
