please help im going mad
fritzwells
fortec star passion
norfolk
hi all
i have recenntly perchased a fortec star passion system so i can whach the HD channels.
the problems is i thought i would be able to set it up myself.
i have a compass and a sat finder
i have the dish pointing 28 degress and the sat finder goes crazy, then i use a little up and down then left and right to get a strong reading
then go indoors the the box reads no signal
i have been at it all day 'O'-red just cant sus it out
am i missing something
So I presume that when you scan for Astra 28.2 channels it finds nothing?
You have probably not found the correct satellite, when scanning, does the box find any channels?
fritzwells
fortec star passion
norfolk
at one stage this afternoon i got a few italian channels and some arabic ones but since then i have tried again and now i get nothing
no matter if i have a strong signal on my sat finder the signal strength and quaulity bars on the set up menu remain at 0%
i only seem to be able to get one sat signal with my finder
:confused
satelliteman
Sounds like you found 19.2e or 13e instead of 28.2e
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
:confused
Next time you manage to get some channels, bolt the dish up.
Then check what channels you have and their frequencies (Just a few of them), then look them up on kingofsat or lyngsat to find out which satellite it is was.
Once you know which one it was you can work your way round the arc, to the one you actually want.
Robbo:)
EDIT:- KINGOFSAT channel search facility, very useful :)
_http://en.kingofsat.net/search.php
fritzwells
fortec star passion
norfolk
thanks robo i will give it a go in the morning
