News Update ....
After trying code after code with a PC programable remote from "Jolly" I found a code that "worked" number 4455 from their list, decided then to set myself the task of about 100 plus codes a night! in the range that centred on satellite codes 4xxx to 49xx.
When I found this code my next task was to find any use of it by others, and at long last the brand of STRONG showed up with models SRT4155/4355/4375 maybe also 4255 but I could not prove it. Also a copy remote was listed from CME number 3975 but this brand are not around as much it seems now, so after trying various companies located one made by (remotes4u.co.uk) for a SRT4355.
Most of the keys are correct, just a matter of getting used to strange remote button symbols that relate to certain functions.
I am aware its an old model but if it all works as I hope, it should be good, with a dual type receiver plus radio, at the moment I am filled with inspiration now that it works my task of bonding heatsinks onto poor chips that get hot continues to ensure reliable working.
May seem a lot of work but it can be fun and to recycle is a good thing, all thats left is matching it up to my old patio type dish mounted on a wall, which will pivot between 19 and 28deg.E when I get time to adjust the mechanism.
If anyone can help with a correct remote or paperwork on this model I am still interested
deltatango
