Problem with SR 29500 Transponders
Guban
Fortec Star Innovation HD
Technomate 1000d
Vacarro Eliptical Dish
Strong Motor
Galway,Ireland
I am unable to get a signal from transponders with an SR of 29500 on the Fortec Star Innovation HD receiver. Any ideas on settings that I may need to change. I have excellent reception S 80% and Q 95%. I have no problems with HD channels on 22000 or 27500. I know the channels are encrypted on 29500 but should they not show up in the signal bar? Any help appreciated.
PeteB
Maplin supplied
Fortec Star 80 cm motorised dish.
Fortec Star Innovation receiver / 8Gb USB stick.
Central Scotland
You don't say what firmware release you are on
The latest is ver125
Can you give me an example of a transponder you can't bring in?
Guban
Technomate 1000d
Strong Motor
Galway,Ireland
Hi Pete,
The firmware installed is V125 (I see V126 is avaialble now). The transponder I have tried to bring in is 11798 H 29500 (Ch4 HD). Thanks.
Don't know about the Innovation, but C4HD OK on my Passion HD with latest FW Dec 1st, indeed with previous ones too.
Guban
Technomate 1000d
Strong Motor
Galway,Ireland
Could it be a problem with the LNB? It's an MTI quad about a year old. I have no problem with the other Sr's and signal quality/strength is excellent.
Wouldn't have thought so. Sounds more like a tuner problem.
Guban
Technomate 1000d
Strong Motor
Galway,Ireland
Problem solved after upgrade to V126. Transponder for Ch4 HD was incorrect on Lyngsat it should be 11797 H 29500. Thanks.
