Problems setting up Harddrive and flashdrive.
jase1
Vu Duo2,1.2 CM,1224 H to H 57E-30W. Sky dish.
Cheshire
Can anyone help? I'm using the latest Dreambox UK image on my clone 800se.
I want to set up the cross epg to the flash and recording to the 320g harddrive. I'm going round in circles mounting, unmounting.
At the moment I'm looking @ DCC and the hard and flash are showing but when I go into configure on the cross epg I cant select the flash. Its just giving me the harddrive or internal flash options.
Also in DCC under memory info the root is showing as 90% used Is this the internal flash? I dont think this looks good
I dont want to start messing with things I dont understand but I dont seam to be able to sort it. The info I've found shows different menus or is for different images.
Jase
jase1
Cheshire
Has anyone come across any of the above problems?
Jase
andyxxxx
DreamBox DM800HD - Technomate TM600 - Technomate TM500 Super - SkyBox F5 -- Triax TD110 Dish on TM2600 Motor - Zone 1 sky dish
Newcastle, UK
It may be the same problem I was having with CrossEPG.
As long as the flash drive is mounted, make sure the 'reload on boot' option is unselected in CrossEPG then restart the box and go straight into the CrossEPG settings and you should be able to select the flash/HDD and set up CrossEPG.
Unfortunately it seems to be a bug and you have to restart the box every time settings need changing.
jase1
Cheshire
As long as the flash drive is mounted, make sure the 'reload on boot' option is unselected in CrossEPG then restart the box and go straight into the CrossEPG settings and you should be able to select it and set up CrossEPG.
Thanks Andy I'm on it.
Jase
jase1
Cheshire
Jase
Still no joy, it looks like theres a problem with the usb stick as the box cant see it.
