- Mar 29, 2004
- UK
Hi moonbase, you can get a pc interface for positioning, I need to look more into it, you might find the information useful.
Research Concepts Web Server
https://www.go2mhz.com/SpecSheet_mhz.asp?strPagID=2626&strSolID=9
blademedia,
Yes, you can control the RC2000 from a remote location using the web server add on module. However, both the remote location and the local location need to be on a VPN or a WAN. It does not work unless there is VPN or WAN connectivity at both sites. The web server module does not use TCP/IP protocol, it uses UDP protocol.
They have an online setup available that allows you to logon to a web server module and control it from your local PC.
I have pasted the details below, if you want to test it I will PM you the user ID and password.
http://64.126.122.59/webgui
you can also go into the configuration setting with a /config
http://64.126.122.59/config
Front Panel operation is located
http://64.126.122.59/rcfp
Rgds
