- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
Chr0nik if I remember you use the same meter as I do, a Satlink 6933. If so it will be worth checking the 30°W transponder being used has the correct details entered, there are a lot of duff ones in the list.
On 52°E try fiddling with the declination. Working out if you are above or below various satellites is the key to how to solve it.
Just Sharing This - Strongest transponders
The Strongest transponders for January 4th 2021 All active Ku band satellites from 50° east to 45° west This list was compiled by William-1 $ = encrypted TM5402HD M3 +100cm Dish+Inverto Black Ultra Lnb-Signal Quality in dB Turksat 4B @ 50° east 11196 V 2222 TürkSat Tanitim==14.7 AzerSpace-1 @...
www.satellites.co.uk
