Advice Needed Received a Channel Master 1.2m - slight damage to face & what are my motor options
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I do not know. I, personally, would use 18-incher for 1.2m CM.
zorrin
Specialised contributor
France
www.facebook.com
CM 120 Ku 52°E to 45°O
CM 120 Ku 50°E to 45°O
CM 120 Ku SDR 25.8°E
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
GTMedia V8 Nova, V8X, V8 UHD 4K, V9 Prime
Edision Piccollo
france
Hi @manikm909
we are working on the same job i just started painting my two CMs.
I started with two coats of matte white primer.
After that I would pass two coats of matt white paint.
Here the back of the antennas before the primer
with the primer
fronts without primer
and fronts this time only the one on the right received the first coat of primer
i started a post about it : Another Channe Master SMC 1m20 restoration X2
hope it will help :)
Manikm909
Small'ish Dish Man
Kent, UK
ive finished the polarmount now
zorrin
France
www.facebook.com
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
Edision Piccollo
france
with the paint it will be difficult to find the markings for the adjustment.
I advise you to buy an inclinometer.
Manikm909
Small'ish Dish Man
Kent, UK
thanks - if u mean markings on the screw - i left them visible
however i dont understand at what point of the screw that the marking represents your lat \ long
I wouldn't bother with the sticker on the bolt - a digital inclinometer like zorrin posted makes setting elevation very easy, as well as for getting the pole plumb.
zorrin
France
www.facebook.com
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
Edision Piccollo
france
Yes the pole plumb is very important.
danaddison
100cm Sat dish on Superior Dark Motor Metal Gear DiSEqC 1.2-1.3 USALS GotoX, connected to ground pole
With the moteck H180 motor the clue is in the name.
In theory it should provide a 180 degree arc or somewhere close to that. It will cover more arc than a general polar mount with actuator.
Any outdoor paint will be OK as long as it is not the metallic type.
I seem to remember spray cans of non metallic car paint being used by forum members in the past?
With the polar mounts I have used the actuator has been fitted on the left side of the assembly if standing at the rear of the dish, ie, the East side if in the northern hemisphere.
The actuator extends to push the dish westward and retracts to pull the dish eastward.
An actuator fitted for up/down movement is generally referred to an an inclined orbit actuator.
With the moteck H180 setup, although it does not use an actuator for East/West movement there is an easy modification to fit an inclined orbit actuator.
Removal of the elevation bolt and replacement with a small actuator adds inclined orbit tracking to the E/W motorisation.
I have attached below a picture of a moteck H180 motor fitted with an inclined orbit actuator that I setup for a client.
The moteck H180 in the atached picture is fitted with the Channel Master plate that is usually shipped with it, the CM 1.2m dish bolts directly onto this plate.
where did u get this from ?please DM thanks
Manikm909
Small'ish Dish Man
Kent, UK
i didnt use polar mount in the end btw
i got a JAEGAR SMR-128G
you can try and get one of these:
danaddison
were did u get the plate from for your dish?
Lots on Amazon, eBay etc., but do read the reviews as some seem quite poor ( from the comments!).
danaddison
Lots on Amazon, eBay etc., but do read the reviews as some seem quite poor, from the comments!
whats it called cm 1.2m face plate?
Manikm909
Small'ish Dish Man
Kent, UK
it came with the motor - it was off a 90cm CM - got the dish and the motor for peanuts.
u have to constantly search ebay or set alerts up.
as for the plate, its just a bit of metal with 4 holes in for dish, and 4 right angled lugs for motor attachment
u can forget new stuff mate in the 36v world.
danaddison
ok thanks
No, I will not DM you.
I have already told you in DM's that I am not your personal satellite advice hub.
If you have questions post them on the forum and await replies on the forum, the answers may not only help you but also help other users in the future.
danaddison
rude!!!
I have already said in a PM to you that you can forget getting a plate new, as Manik has already said, any 36v motorised accessories are not made anymore, so you will need to search Ebay as I also already told you!!
Not really, I told you to stop DM'ing me for advice yet you carried on sending DM's.
I am happy to add a member of the admin or mods team to the DM conversation to substantiate this fact.
My reply above is not rude, it is a plain speaking reply informing you of the status.
It seems that you are also bothering other forum members by DM asking for advice?
As regards your question about the Moteck H180 motor with inclined orbit tracking for a 1.2m CM dish.
I bought the Moteck H180 motor from one of the online retailers. I used a LINAK optical actuator for inclined orbit tracking that came from a batch I bought as end of line stock.
Manikm909
Small'ish Dish Man
Kent, UK
we should all go down the pub and thrash it out
Aye, good idea.
Local pub round 'ere got world experts on every topic you could think of, they get more expert deeper into the sesh you go.
You can see them sneaking off for a pretend "tom tit" ready to google the bitch outta their mobile phone in the Khazi, returning to the bar as the font of knowledge.
