Relook 400S, the world's first Linux Twin-Tuner PVR
Likvid
Stockholm, Sweden
Ohhh....i dont have any experience of the listed receivers you show.
Sorry, the only digital receivers i owned are the ones i have listed.
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
I see. Anyway, if you say that the sensitivity is comparable to the Topfield 5000 then it is in the upper league.
bigsinky
DVB Freak
1.1m triax motorised from 28.2e to 30w, relook 400, dreambox 7020, DM500, skystar1, nokia 9500,humax FTA, full 7.1 home cinema
xp4600+ @2.7GHz(aircooled) , 4.5TB HDD, 4GB SDRAM, Dual 8800
Belfast
including a real chassi compared to Dreambox cheap plastic chassi and faulty power supplies and weak tuner,
@likvid are you referring to the new Alps tuner that is in the new dreambox 7020s. i found it to be the best tuner i have ever used. is the 400 tuner that much better?
cheers
sinky
Likvid
Stockholm, Sweden
cheers
sinky
Don't know if it was the Alps tuner or not in mine.
Every receiver is better than Dreambox on the market when it comes to the tuner....
Maybe the new DM7025s will be better, don't know, but i wouldn't risk 699 euro for it, its too expensive as well for what you get.
OldBen
Mad Scientist
Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch. VU+ Duo. Emitor Satlook Lite meter.(Retired: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB
lloyd21 said:
O.K. what does the keyboard look like for this, looking at the pictures I dont see a PS2 or a USB for getting in Terminal, built in infrared? Is it based on RedHat which seems to be popular these days?
According to their website "Embedded Linux (Kernel 2.6.9)", I would have thought they have a tailored image for the box that is nice and small. 2.6.9 is not bleeding edge but its pretty new...
Paul.
Likvid
Stockholm, Sweden
Some more pictures of the beauty.
galerie_onfly.php
galerie_onfly.php
