OK, VS, I see you want to go 16mm glass feedarms. Then take 3x1m, drill 5mm holes from at the ends and make internal M6 thread in those holes. Then take pieces of M6 threaded rods and fix them in the feedarms. On the attached picture I made a model to better understand the idea. If you get issues with the internal M6 thread, later you can enlarge the holes and thread M8 inside.
Thanks for the suggestion Rima.
I've found a way to contact CarbonFibreProfiles by email and have sent this to them.
I'll wait to see what response I get if, if any before making any decisions.
Hello
I think maybe you could help me.
I am trying to restore a 1.8m satellite dish made in the 70s.
I only have one good feed support arm ...two if you include a slightly damaged one.
made from glass fibre.
16.2mm diameter would be fine for this but the lengths you sell are close at 1 mtre...but I need 44.5 inches (105.4cm) thus the 1 mtre lengths are too short and the next size up 2m are far too long.
Also this would make the cost of restoring very expensive.
My questions
Could you provide 3 glass fibre tripod arms of the required length ?
Cost is an issue so if you can supply them...an idea of total cost including shipping to me would be very much appreciated.
I am in Manchester M27
I appreciate this is not a from stock request...and a one time order.
Many thanks for reading.
rgds
E Parton
an old satellite enthusiast.
..you never know they may have some odd lenths / damaged stock ...
