Saorsat LNB - Linear Mod?
remlap
remlap
Wales
Anyone seen any mods to turn the Saorsat LNB to linear now there are feeds on 7E?
Cheers
2cvbloke
2cvbloke
Bulbs need shelter too...
Near Pontop Pike, Co. Durham
Looking at the frequencies on Lyngsat, maybe the easiest, erm, "mod", would be to swap the Ka LNB for a Ku LNB perhaps... :confused
remlap
remlap
Wales
Well no, there are KA feeds on 7E, but I've been told on boards.ie they're not in the range the Soarsat LNB does.
Hixxy1
Hixxy1
East Midlands
There's a bit of info on here with people using different types of lnb. Norsat spring to mind.
Would be good if someone did mod a Saorsat lnb.
_http://www.dxsatcs.com/ka-band-reception-videos
remlap
remlap
Wales
Have to wonder if there are any DVB TV feeds in the 19.7-20.2GHz range the Soarsat LNB takes.
satosk
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
"Anyone seen any mods to turn the Saorsat LNB to linear now there are feeds on 7E?"
K band (K band: 18-26, Ka band: 26-40 GHz) covers 4 different bands and each of `em covers 1000Mhz. You can not get different band with the Inverto ka band lnb...nor even linera polarization of the same band! The only weay is to use a necessary lnb, feed and omt to get both polarities.
In general it is called Ka banad even it is not the band downlink operates in....
A) 18.2-19.2 GHz
:cool:19.2-20.2 GHz
C) 20.2-21.2 GHz
D) 21.2-22.2 GHz
There are DRO LNBs available for the first three bands, unfortunately manufacturers offer for the 4<sup>th</sup> band PLL LNBs only. There`s a reason to do so I guess.... What`s can bother us is the price of PLLs as a PLL lnb by Norsat costs ca. $1500-1700.
satosk
satosk
Well, I wanted to attach more pictures but it gives me only this terrible size option and I`m not going to resize a picture to 2x2 cm!
:-downt You can upload up to 56.87K of files (Max. single file size: 56.87K) :-downt
remlap
remlap
Wales
That's some collection of LNB's there. Thanks
satosk
satosk
It looks that it allows to uploade proper size now (Max. single file size: 10MB) so here we go again!
Different stuff for Ka band reception.
Single polarity OMT and original Ka band feedhorn F/D 0.5-0.7, both made by Prodelin.
Hixxy1
Hixxy1
East Midlands
There's some interesting reading here where the person has modifed a directv lnb.
www.uhf-satcom.com/kaband/
