Saorview Sound & Epg, But No Picture
J
JonnytheKid
2 Panasonic TU-DSB30 digib0xes, FTV cards, quad LNB, Zone 2 dish, & VCR (remember those?)
rural Northern Ireland
Hello all,
Using a Dion UK freeview box (from Tesc0) I can get all the Saorview channels at 80-90% strength. I get the sound and the Saorview EPG, but with a completely black screen instead of a picture.
Tried swapping it for another idential Dion freeview box, and get exactly the same result.
A newer UK tv (in the living room, with an integrated digital tuner) gets the Saorview channels without any trouble at all.
Anybody any ideas? :confused
Thank-you in advance for any help offered.
M
mbsnr
Sky+ HD - FTA 43W to 42E
Ireland
Best guess is the TV without a picture only has a MPEG-2 tuner.
The other TV looks to have a MPEG-4 tuner so can display the Saorview picture.
UK freeview uses MPEG-2
Saorview uses MPEG-4
Which is why a lot of the older TVs, which work with UK Freeview don't work with ROI Saorview.
M
mbsnr
Ireland
Re-read you post - you said Freeview box not TV - but the same applies about the MPEG-2 tuner.
J
JonnytheKid
thank-you for your wise advice. Might be time to change the old tv :-)
M
mournespide
Sky+HD box with NI card and no subscription.
Saorview, Basic Freeview and Roku.
Co.Down (near Claremont Carn transmitter)
I have been receiving Saorview from a relay transmitter (Greenore) and not Clermont Carn since October 1st! Signal is good and I can use digital text and view RTÉ 2 HD.
Chris76
Chris76
Vu+ duo with a 300gb hdd also dm500 and tecnomate 5200 with a 1m and 1.1m motorized dishes and minidish fixed to 28.2
Belfast
Get yourself a freeview HD receiver this will get saorview from Roi and from divis transmitter in ni.
Sent from my iPhone using Tapatalk
