- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Does anyone have knowledge of a PCMCIA module or bolt on accessory for receiving satellite signals into a fast running laptop ?
If so can you recommend a make that will work on Windows XP and maybe have a DiSEqC 1.2 function for motorising the outdoor components. If the Laptop battery is the part that causes trouble in suppling the correct voltages to the LNB, then an option of power pack/inverter can be fitted into the cable to provide 18V with a constant supply into the laptop as this is to run from a van
Any help in tracking one down would be great.
This is a project for reception of satellite signals in a remote area
