Sky Italia box
Ive just managed to get hold of a cheap Sky Italia digital receiver (Amstrad DRX 500) :) So heres a few thoughts / comments about the reciever. These are first impressions - all the menu options are in Italian and I know very little Italian.....
The basic menu structure is very similar to the UK boxes, which makes it reasonably easy to navigate around
UK remote controls operate the box
Theres no rf connections on it (which is causing me problems as I need to wire it into my distribution system!) I need to shift the tv round in the living room and scart it into the video recorder...... However with a temporary lash up....heres some screengrabs
Heres the basic no signal screen (havent got round to connecting it to a dish yet!)
Heres the basic services menu
"Services 4-0-1- Select" works on the Italian box just as well as it does on the UK boxes.
Default frequency is 11880V 27500 3/4
Zorba
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
How many scart outputs are there? You could connect an R F modulator to the scart socket.
Heres the tv set up screen
Interestingly theres a disecq option ("hard wired" for what looks like 13E / 19E)
Now this is very interesting - is this a basic motorized setup?
2 scarts, and whilst yes I could connect an rf modulator I dont have any lying around
More pics once I get a 13E dish connected - quite a few of the options dont work when there nothing connected....
satelliteman
I installed a few here for Italian customers. You can normally get around the menus fairly easy.
Interesting to see what happens if you put a 28 feed into it or a motorsied
What has surprised me a bit is that all the screen printing on the front panel is in English!
satelliteman
There must be a way of programming it to display English, failing that a good Italian phrase book will do...
freehair
:cool:
Or you could have some one to translate it for you!!
Yea so the motorized page is.......... well just the same call on English one on the engineer menu
lnb setup
With the added motorised call. Setting
It is the same just has the English one with the software modified because in Italy the antitrust law determined that users with D+ contract could use their unit for n…, so Murcrap )(-redcompany did minor modification to the software to comply and also issued for a very short time N card for it
Do you remember the rumour there was a N cam available?. On the open market!
Well about that I do not know anything because I when in to the COLD by then….U-zzz
But I am backkkkkkkk:-rofl2 buonanotte a tutti heeeeeO-zzz
freehair
:confused
Ho bad away to the question "does it works on 28.2east" YEA it does ...
:eek: But the funny thing again is as for the English stb I can have the Italian (13 east) channels just on the add channel menu sub call and stored on the other channel menu.
You can have the English channels on the
menu call 7'O'-red
“Gestione Altri Canali”???
But it will not allow to have them on the EPG, I don’t understand same encryption N.. and software in the box, any one suggestions!!!!:-Nooo
Humm I wonder should I go in the loft and get the old gismos and do some patching tests.... soldering etc... Would that be legal to do test on old units recover from the council dumpster?:-rofl2
2cvbloke
Near Pontop Pike, Co. Durham
Wouldn't it be funny if you did a software update on 28e on the box and it downloaded the BskyB software and vice versa? :D
I know, it's very unlikely, but it'd be funny to see... :D
when the card inside write me errore 08
programmi disponibele
any idia what is it ?
hdfreak2d
Humax HDCI-2000
1.5m dish
central Italy
That's "error 08" and "available programme"
is look the card cant update
secend card errore 04
Yeshi
Norden - Near Edenfield (not Rochdale)
Dm500, TM9100, Samsung V+, 1M Dish. Motect 2100..
37Inch Plasma, Wii, Xbox360.
Behind pin 9 on an atmel
Analoguesat do you have AT chip reader??? fancy taking your box to peices??? woudnt mind a dump of that software... have a few donating uk boxes.. posibley set them to motorised??
