Sky Italia box
For the first time in ages Ive had time to have a play with my Sky Italia box, and Ive found an interesting feature hidden deep in the menus. You can add channels and access them direct through the epg in the 96xx range!
Here you can see Ive added Caspionet first and its on 9600
Rather more flexible than the horrible "Other Channels" on a sky uk box isnt it?
That's a good idea, perhaps BSkyB will follow suit eventually, although there is not quite the same need for it on Astra 28.2, as there are a relatively small amount of channels not on the Sky EPG.
satelliteman
Nice result A/S.
Where abouts in the menus can this be found :D
Services, 7, 3, SELECT to load the other channels - it loads them all in alphabetical order which you can then find in Services 7, 2.
Beware - Each time you run the Services, 7, 3 it appears to delete your existing 96xx channels!
satelliteman
Made a note of that one :-righton
celtickev
WINDOWS XP
NEWCASTLE
hello lads my local has sky italia for the football how do i access the english audio if its available what buttons do i need to press on the remote? any help appreciated thanks.
If its a Sky Italia box you want
Services, 4, 3
Set the top option to Inglese.
combridge
azbox premium
viasat hd,sky hd,
tecnomate 6900 hd
1.2 motorised dish
1.8 precision
staffordshire
my sky italia has arrived and fitted only problem i have is can only get it on one tv i want it to go to three other s theres only two scart wondered how it can be done i run sky and tecnomate through a amp but as sky italia only has scart sockets don t no how to do this one thanks
Connect the scart to an old video player and output the rf from the video to your distribution amp.
Or buy an rf modulator from somewhere like Maplins.
combridge
azbox premium
viasat hd,sky hd,
tecnomate 6900 hd
1.2 motorised dish
1.8 precision
staffordshire
thanks ill try that
ryangericks
fortec star passion hd
bought from maplin
english
ihavejust bought a sky italia package from a company in london.i also have a motorised disk on a fortec stat tuner . can anyone help .can i set or how do i set it to english on the sub channel i have a very good picture as all i done was was set the motorised disk to hotbird unpluged it and pluged in the sky italia box
You havent read through the thread have you?? That has already been asked & the info is given in posts 46 & 47.
fergyc
VU+ Duo with ViX and OSCAM, Prof Revolution 7301 PCI Card, 2x Dreambox 500S, 80cm Technomate Dish with Inverto Black Ultra and TM-2600 DiSEqC Motor. Technomate TM-300D along with a few zone 1 minidishes that get moved regularly and a zone 2 for 19e a
Northumberland
2cvbloke said:
Wouldn't it be funny if you did a software update on 28e on the box and it downloaded the BskyB software and vice versa? :D
I know, it's very unlikely, but it'd be funny to see... :D
Doesn't work when you try and force an Italia update on a UK box unfortunately :(
Ive finally got around to changing the wiring in the living room so I can have my Sky Italia box wired up more regularly. Ive updated the software on the box and all the second satellite option in the in the 2 lnb via disecq setting has changed - it was just "hardwired" for Astra 1 before, but now its a choice between Astra 1 & Eurobird 9
