RubyT
- May 21, 2021
- Age
- 50
- SKYBOX F3
- London, UK
ThanksAs the dish is not motorised you don't need to input longitude and latitude. Set Motor Type to OFF.
It’s the loopWhat is the white cable connected to? Also what is the text under each connector?
u think I have them round the wrong way?Having looked at an image of the F3 rear panel, top connector seems to be LNB and underneath LOOP. Therefore if the black cable is connected correctly to the quad, it should be in the top position.
YesIt’s the loop
OMG I’m such an idiot… just switched the cables around and the channels are back. Thank you all for your help …It’s the loop
Agree taking it out…. Don’t need this headache again. Will keep a note of the settings as The Astra 2 doesn’t seem to be the default. Thanks a million again.Pleased we could help you get it sorted. However, out of curiosity, where does the white cable go? If not to another receiver, I'd remove it to avoid confusion in the future...
