Skybox F3
Yes Ive still got the Duo - and its still as detested as much as it was before
I strongly considered the M3, but was concerned about overheating and about its ability to adequately source motor current.
nelson_b
Contributor
wod said:
does anyone have the m3 model i've seen about, could do with getting one of these as the dr hd f15 seems sold out.
yes i have the m 3 -- but i,m only using it in a very limited way so far ----- i use it as blind search tool --- its connected to one side of a twin output l.n.b -- on the 1.2 channel master dish.
but i don,t use the m3 to move the dish , its moved by an old Technomate 5500 DAPCI (36v output)
the m3 is the smallest reciever i,v ever seen -- its powered by one of those 2 pin plug in mains transfomers output12 v ---
cheers --:)
Costactc
Canada
Always use laptop cooling fans with any stb that I have heat issues with.
nelson_b
Contributor
Analoguesat said:
One quick question - does the composite (yellow) video work - with no scart on the box I would need that to connect it to the rf modulator I use in my distro system.
No tvs at all with hdmi here - even component is too new for out kit :D
I would swap one of the numerous spare SD only rx's but thats no good for looking at the S2 52.5E stuff.
The composite is fine on the M3 -- i have it connected to an old panasonic tv
as well as hdmi to a samsung 32 in -- it displays on both ok at the same time --
wod
yorkshire
Are there clones of the skybox f3/m3 because looking on the auction place they seem very cheap and there is some with included gift which i will stay away from.
Costactc
Canada
Menu looks Identical to the f3.
Not quite sure about clones but these units are priced just right- bang for the buck.
sam_x11
satellite and computer
leeds
HI, Recently I got SKYBOX HD Receiver F3..often get chennels getting scrambled and also I can not find the Password, I "0000" and many more combinations but no luck >>> PLEASE ANYONE CAN HELP ME ? PLEASE !!
What are you trying to access that needs a password?
If you received a "free gift" that allows you to watch scrambled channels and you need a password for this, then this is card sharing and discussion of this is strictly forbidden here.
wod
yorkshire
In the skybox f3 there looks to be a cam slot and card slot do these work ?
I have aljazeera sport card and irdeto cam that I will be using and also a cyfra+ card.
otherwise I will get a tm5402hd.
Take it up with your seller - we cannot help in this case.
Cheers bud :)
Now I know I can interface it into my distro system I shall buy a none gift one.
Ghostleader
Glasgow,ish!
I have the same two cards and CAM combo running on my TM5402 HD works flawlessly, I also stick a $ky italia card in the card slot from time to time, CCcam is also spot on performance wise.
rossy
Skybox f3 spiderbox died hd9000 technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky,
Span 58W to 42e with trees bare! 42e gone and now 39e
southern england, Berkshire
The composite Yellow works ok. I use that to Feed a RF modulator to put the video around the house . I think you will be pleasantly surprised by this receiver and I love the blind scan which is sensitive and fast.
cheers
Blimey the F3 is tiny :-rofl2
Playing with it will have to wait until yomorrow as Im so tired Im absolutely spaced out tonight.
wod
yorkshire
lets hope you like this one, just noticed your system entry "vu+ duo dreadful software" haha.
Good job you didn't go for the M3 then - scarcely bigger than a fag packet.
(Note to our US friends - fags are something we put in our mouths and set light to here)
Well Ive got it set up for 53/52.5E and its currently scanning 42E.
The blind scan missed the Uzbek tp completely so Ive had to put that one in manually.
Sensitivity - too soon to tell, although the "signal meters" are showing lower than the old secondhand GDS 7000 its replaced.
Pic quality is better - Uzbek tv was very "muddy" on the GDS, thats sharpened up quite a bit.
The remote is remarkably insensitive to button presses - it sometimes needs a really hard press to get it to do anything.....
Oh and in a sad reflection of what these boxes are often used for 28E was already set up with the Sky Sports HD channels on the first set of channels. Think those can be deleted pronto!
Surprised at your comment about the Telecommander - perfectly "normal" here: Maybe some less than pristine batteries?
I assume the avatar cam is a payserver cam as I havent heard of that one before.
