dave branson said:most likely a daft question,assuming the outputs are low and high with associated cables,do the cables get joined up somewhere,to make one lead
to the end application?
steffan_st said:Hey Dave!
Haven't you cut the feed off the Titanium before you attached it to the feedhorn?!? The waveguides are supposed to mate with a diameter as close to each other as possible,otherwise you can have a standing wave problem!
I don't say it would get better but I think so.The conversions I have made that way works very well,for example I cut an Interstar GI-201 and mated it with another feed (cd-80),used it on my Gibertini,the increase was 14 % on Astra 2d!!!
dave branson said:Hi Steffen
I cut the feedhorn from the Smart,and attached a 120 c flange,is this what you mean?
dave branson said:Ther is about 1mm difference in the bore,between the flange and the LNB.
dave branson said:As a matter of interest,does anyone know were you can buy C120 Flanges
Likvid said:Here is a setup in Russia using the SMW dual outputs LNBs, but the concept is the same, don't ask me price for those beasts, they cost a fortune.
erosennin said:One guy was selling this feedhorn with the LNBs for internet use, one long (but smaller than those two) and the other one short.
Can I use this feedhorn with the 0.3db invacom c120?
In this case one end would be useless (the bottom one I suppose), do I remove that section then?
I don't have the feedhorn but you never know when you'll find a good deal..
Please see the attached picture.
thanks
snap said:An Invacom C120 will bolt onto the feedhorn directly, you can lose everything else.
Use a Quad QDF-031, it's the best one they make.
dave branson said:Managed to get the time to install the smart LNB with C120 flange on to an Invacom feedhorn,reception was ok,till 19-00 hrs then the signal died,
I replaced it with an Ivacom single LNB,and received a pixelated picture for about another hour.
It seems obvious that the Satellite moves its position,55% quality to 0 in the space 45 minutes tends to confirm to me,that nothing will change untill the
Satellite is repositioned.
steffan_st said:So the modification of the Smart didn't improve your reception compared to using it uncut and attached to your feedhorn?!?
