Software For Star-Sat ???
Alexy
Hello
Does anybody know where I can find the latest version of software for star receiver (SRX 150D+)? I've heard the newest version is 2.49 .
Plz help me!!!
tweek4444
Samsung DSR9500A CI
India
Hi
You can get software for starsat receivers from www.star-sat.com (or) from www.satsw.com.
I have also downloaded software for my receiver Starsat SR-X650CI form satsw.com but after updating receiver is not working. Its exactly the same model but I dont know what happened. So you make sure whether the file you are downloading is the correct one for your model. You can verify and ask support, by sending e-mail to starsat@emirates.net.ae
Now I am searching for the actual software for my receiver. I advice you before upgrading you take a backup of your existing firmware using windows hyperterminal etc.
good luck!
Alexy
Hello Tweek,
Thank ya very much for ur guidance. I'd gone to satsw.com and 'd downloaded the true software for my receiver. But unfortunetly its version was 2.40 which I'd had. I don't think that the softwares in satsw 've become newer in these days.
Now I'm searching the latest one.( probably V 2.49 )
PLZ HELP ME !!!
tweek4444
Samsung DSR9500A CI
India
hi
The above websites are the actual sources of the Starsat support. So I think the file you have downloaded is the latest.
trailblazer
alexy,
can you get nagravission programs with your X150D ?
tweek4444,
how to back up the existing software tru hyper terminal ? what about STN5518.exe loader ?
SilkTech
Dear frnds
Am having Digital Satellite Receiver StarSatar SR-X120D plus and its model id :E124 and h/w:2.10 and S/w:2.40 this receiver when i purchased the dealer told me that it is without cam or smart slots but the company has open some channals (Adults+Children), well after two months those pay DisScrambled channals vanished ,i contacted the company they told me to download the software from main home page, the home page software for my Receiver is exactly 1 year old and then they told me to log on www.satsw.com and download latest softwares from there , Sir! again notice that there softwares for my Receiver is old ,when i contacted the company they stop Responding me ,now this type of Behaviour is not good as a company for these Systems, they should have to provide customers fully informative records instead of putting out of Date Software in their Site, It is said the the newer version is S/W:2.49 but where to get it the company suppose to launch it first, what can we do for this is there is a solution of this problem.
Morvan
Doha, Qatar
Alexy said:
Hello
Plz help me!!!
Did you find information about newest, can you tel me mor about that.
thank you
mo1965
behrooz1363 said:
hi evrybody.
tweek4444 can u please tell how to upgrade my receiver(starsat sr x-200ci).I mean how can I connect it to pc and how can I upload the program to it?
will u please tell me about coding by remote control?
thanks.
Look you lot satsw has the most recent software all you have to do is find the coorect and latest for your receiver.
Yes some/all channels may stop because they change the keys regularly and you have to change them yourselves using the remote control or if can use 6in1 fun eeprom hex file. It is included in the software with loader once unzipped.
ychieve
To
The Manager,
LG
Most respectable sir,
I am Yaswanth. I am M.Sc. Electornics graduate. Here I am running a cable network system. I am using your Digital Satillite Receiver i.e LG(LGI-6000 FTA)11 nos. since long time . Really the features and functions of your receiver is very well and the working condition is also very much satisfied.
In that recently, 3 no. receivers are software problem.
So, I am humbly requesting you sir, please send me suitable software , so that I will be enjoy with the said receiver. Otherwise the receiver will be kept idle and it may be spoil .
I am once again requesting you sir, please cooperate with in this connection. Because you are only the person to do some thing in this matter.
Thanking you,
my email ID:ychieve@yahoo.com
amirkhan
hello everybody:
Is there any software for unlocking the eurostar 2ci reciever in order to unlock the scrambeled channels?
thanks alot :)
harrypotter
Hi please help me.
for programming my receiver (starsat X-200CI) i did:
1.Went to www.satsw.com.
2.Downloaded item number #11 which is loader(emupgrade)
for starsat and installed in my pc.
3.connect nine pin female+female(rs232c cable) for
connection between pc and receiver
3.Started the loader(emupgrade) and browse for bin file
sr-x200ci (I downloaded this file from www.satsw.com).
4.Checked my current model I.D, h/w version, s/w version
from STB status of my receiver and compared with the
laoded file on emupgrade.
5.my current model (receiver) is h/w ver=2.00 , s/w
ver=2.55 , model I.D=E224 and for sr-x200ci file was hw
ver=7.00 ,s/w ver=2.64 .model id=E224 ??? (after E244
was 3 question mark) therfore I pressed start button
of emupgrade for downloading.
6.Powered off my receiver from backside and restart
again.
but nothing happened !! what is wrong??
(maybe I should say peressing 1234 I
entered STB setting and I deleted all
viaccess codes manually)
please answer me what should I do step by step.
Have a nice time.
thanks a lot
harrypotter
Hi.
I want to update the programof my starsat sr_x200ci receiver but when I press menu and go to Instalation and then press ok on Transfer data nothing happens.
how can I transfer data between receiver and PC.
thank you.
DeepDiver
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
harrypotter said:
Hi.
thank you.
Please do not post the same question on more than a thread.
Thanks.
ajahan2005
hello
i clear s/w version of my sr-x120d plus reciever and it not work properly.this message is appeared: not valid s/w version detected!!
h/w version is: 3.10
model id : E124
s/w version: 0
please help me if you know the answer.
thanks alot
d122k7trb
Judas Priest
IClass Receiver
2 Premium X LNBs Hotbird+ Nilesat
120" Dish
Computer system:
AMD Phenom Quad quad core 9750
4GB DDR2 Bus 800 RAM
MB: Asus Crosshair
1 TB Seagate Barracuda 32 MB cache
22" LCD Widescreen Samsung 226BW
SB X-Fi Xtreme
Armenia, ME: The Arab Countries
You can find the patches from:
www.croteam-sat.org or www.satsat.net from which the second one is a Persian site.
I'm also seeking for the patches too.
P.S.: Please Pay ATTN!!!! (FOR ALL)
If the Receiver version is 2.10 then you must download the file that is 1MB else the one that is 2MB.
In other words:
For instance, if the model id= e124
and h/w=2.10
and s/w= 12.65.5
and Ver. 2.10 then, download the file of 1 MB
else the one of (ver. 3.10 or ver. 7) download the one of 2MB.
RB
d122k7trb
Judas Priest
IClass Receiver
120" Dish
Computer system:
MB: Asus Crosshair
SB X-Fi Xtreme
While upgrading you receiver, you must once turn off and then on again your receiver to establish the link between your PC and your receiver.
Hope that you'll succeed this time.
RB
d122k7trb
Judas Priest
IClass Receiver
120" Dish
Computer system:
MB: Asus Crosshair
SB X-Fi Xtreme
Dear Morvan,
The fact is that I'm also seeking for the SR-X 150D Plus patches too.
One Other thing to remember is that in 150D Plus receivers:
and h/w=2.10
and s/w= 12.65.5
and if Ver. 2.10 then, download the file of 1 MB
So please pay attn!!!!! to the version you're downloading. I'm not sure the facts about your receiver, therefore pay attantion.
Yours,
RB, Tehran.
RB
