Software For Star-Sat ???
mt_vaezi
man marta vahedi hastam
where is new program for starsat 150 d+ upper than 12.69.1?
alainc
Aston Simba HD and some others.
Dish 2.00 m Hotbird 13°
saudi arabia
harrypotter said:
Hi please help me.
for programming my receiver (starsat X-200CI) i did:
1.Went to www.satsw.com.
2.Downloaded item number #11 which is loader(emupgrade)
for starsat and installed in my pc.
3.connect nine pin female+female(rs232c cable) for
connection between pc and receiver
;) you need to have only (3)three connections see pin connection on the same site.
3.Started the loader(emupgrade) and browse for bin file
sr-x200ci (I downloaded this file from www.satsw.com).
4.Checked my current model I.D, h/w version, s/w version
from STB status of my receiver and compared with the
laoded file on emupgrade.
5.my current model (receiver) is h/w ver=2.00 , s/w
ver=2.55 , model I.D=E224 and for sr-x200ci file was hw
ver=7.00 ,s/w ver=2.64 .model id=E224 ??? (after E244
was 3 question mark).
;) shut off your receiver
therfore I pressed start button
of emupgrade for downloading.
;) powered on now (you've average 5 second to start it)
now it's working:).
If you get an error message "HW not matched" try the other OLD/NEW soft available.
when the down load is full finish (2-3 min)you can put you keys
whith dreamloader or by remote
6.Powered off my receiver from backside and restart
again.
but nothing happened !! what is wrong??
(maybe I should say peressing 1234 I
entered STB setting and I deleted all
viaccess codes manually)
please answer me what should I do step by step.
Have a nice time.
thanks a lot
;) get fun
blazer2003
blazer
qatar
hi
i have star sat SR-X550D ultra free to air,
plsease can you help me to get a soft ware for it to watch multivision channels
thanks
studenti1
nextwave.... matrix revolution.... need pcmcia and programs to update my mrv with a fujitsusiemens laptop...
al
nabdomi
starsat receiver
this is not update on satdw.com
please advise
DeepDiver
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
blazer2003 said:
hi
thanks
Visit h**p://libyan-team.tk/
d122k7trb
Judas Priest
IClass Receiver
2 Premium X LNBs Hotbird+ Nilesat
120" Dish
Computer system:
AMD Phenom Quad quad core 9750
4GB DDR2 Bus 800 RAM
MB: Asus Crosshair
1 TB Seagate Barracuda 32 MB cache
22" LCD Widescreen Samsung 226BW
SB X-Fi Xtreme
Armenia, ME: The Arab Countries
My idea is that:
The best WEB SITE for downloading for star-sat software is the www.satdw.com because the receivers are classified and one can know which software is for what.
BUT the main problem is that after each upgrade you have to auto search the channels because they get lost. How can we solve this problem, still is a mistery for me!!
The star-sat receivers are not like the strong ones! They need a special software to be added for this kind of problem.
