solar panels (domestic)
spiney
Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
Midlands
"Perfect black" is defined as above, ie, the object behaves as a Black Body! But, saying that gets just a little bit "circular" .....
In practise, then do everything mentioned above, very black paint - ideally graphite based! - and matt rough finish. However, it's diminishing returns .... so just cheap DIY warehouse matt black paint, I'd have thought .....
pgh13
Midlands UK
spiney said:
"Perfect black" is defined as above, ie, the object behaves as a Black Body! But, say that gets just a little bit "circular" .....
Speaking of circular....how about a double skinned dish? Bit of a fag having to run pipes as well as coax but you could have the satsifaction of saying to the council job's worth "it's not a 3m satellite dish; it's a solar panel."O-Ha
spiney
Midlands
That's a very ingenious idea (wish i'd thought of it!), unfortunately a large surface area is required for solar energy collection, so just 1 sat dish - even 1m - is much too small.
In using the parabolic dish in the way it was intended (as a reflector) , the suns energy can be harnessed by focussing onto the pipe, in a far more efficient manner than by absorption.
http://solarcooking.org/plans.htm#parabolic-style
spiney
Midlands
Maybe claiming your 1.8m sat dish is "collecting solar energy" would get round the various local council restrictions? Motorised would help, then looks like it's following the sun, more convincing!
pgh13
Midlands UK
Admit it! You're warming to the idea now aren't you? How about "that's the morning collector; that's for midddle of the day and there's the evening one!"
spiney
Midlands
Ah, that would be the diseqc cookery book !
Solar cookers can look suprisingly like sat dishes, even like waveguide components! ......
http://solarcooking.org/plans.htm .
