I thought you meant a switch that senses whether or not power is coming from the satellite box or not, i.e. a priority type switch. I think you're talking about a switch which operates when fed a (12v?) signal. Again, a problem with Sky as their boxes do not have such an output as far as I know.
No, a standard linear LNB switch will only route signals, it uses what ever DC voltage is coming from the #1 receiver, most linear LNB's (that I know of and have used) use a DC voltage to switch transponders, +13 volts DC will get you all the Vertical transponders on that satellite, +18 volts DC will get you all the Horizontal transponders on that satellite.
So a multi receiver linear LNB switch will have two or more inputs, one for the +13V vertical transponders and one for the +18V Horizontal transponders, it then supplies the correct transponder polarity to what ever receiver voltage is present at the # 1, 2, 3 or 4 receiver port.
So receiver # 1 can be on a V transponder and receiver #2 can be on a horizontal transponder.
