chrisfound
- Aug 24, 2005
- Age
- 68
Dream 7000 + 7025
Sky+ box, On-Dig,
3 laptops, 1 desktop, Win XP and soon '7', OSX on one laptop
- London UK
Hi
I am re-doing this, providing the full information at the start, can someone please tell me if it is the box or the base image that people are modifying that is causing the problem.
Box: DM7025
Hard Drive: WD 80Gig
Software: Oozoon, or Gemini, or nabilosat - does not matter, they are all the same
Problem: Locks up / hangs on record stop
Whether you start the test recording or set a pre-recorded one, start the recording wait 30 seconds and ask the box to stop.
My box responds with either churning cogs or a walking penguin and will not accept any command until you reboot the box.
I have loaded in all the above one by one without an external flash, they all have the same issue.
If you look at other posts, you will understand that I have had a dreambox for quite a few years (dB7000 previousy) and aside from the recent problem of sly card it has out-performed many others that a friend has and he is more of a nutcase than I am.
So before I put an axe through this machine, can someone tell me if they have a solution to this, or have dream f' up and if it is the latter then please can we have the truth.
Also before you reply, please read this post properly but I will give a final highlight.
1. No dual, or multi boot, no flash, images were installed to internal memory
2. Various images tried; Oozoon, or Gemini, or nabilosat - does not matter,
they all do the same
3. No silly answers please
I will state that I have never had this problem on the 7000, irrespective of any image installed - I have looked at my notes and the best software for the 7000 was the davinci 5; it worked for 4 years with no problems at all.
I await your response
Box: DM7025
