T & K wall brackets for 3" pole
sucker69
dreambox
Uk
Can someone kindly point me in the right direction to buy the above mentioned brackets ?
Thank you
Try your local satellite wholesaler, you may need to enlrge the slots though to give you adjustment for mast positioning.
timbo86
Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn.
Belfast, Northern Ireland
Have a look at scc distribution's website. They have a 36 inch set for 3 inch masts. Just register with them and you will be able to view prices.
CROSSBONES
S.Wales
what I did was use standard t & k's, and just drill the new holes.
I used threaded bar as u bolts.
I would like to know where you could get 3" U bolts.
timbo86
I got mine from satellite super store.
wod
yorkshire
on the subject of this, where can you buy 3 inch pole from ? as need one for andrews satellite dish as 2inch aint big enough
do b&Q sell them ? or shall i steal a roadsign at 3am in the morning lol
timbo86
Your close wod. I gt mine from a sign company for 20 quid. they had a load of off cuts lying in the yard. Just need to make sure it is mounted properly as you wouldnt want one of them coming down unexpected.:eek:
aba
chaparral montery 40 fully loaded
ehcostar ad3600ipvia
3 dishes zone 2 / 1 mt motorized / 2.3 m motorized
nottingham
3 inch steel pole from any steel stockholders
3 inch u bolts from any auto factors or exauhst stockists
SST12
Technomate TM6900 Combo. 160G HDD. Technomate TM6902 Super Combo, 1TB HDD. 1.2Mtr Channel Master dish & Polar mount, Samsung LED HDTV's
Eastern England. UK
B & Q also stock a selection of brackets including 'T' & 'K'
wod
yorkshire
can you buy them separate in b&Q as i want to get a couple of k brackets to strenghten my setup
