EDW
- Nov 18, 2003
I have asked to put up a WaveFrontier T90, the guy wants this set up here
h**p://www.multilnbdish.com/images/CPIC_Germany.gif
Looks lile 18 sats. which is pretty cool.
I guess 13 LNB's needs 4x4 way diseqc switches but was else? Is it 0/12v
switch? And then what? Also do you know where I can get an extension arm like the one used in the picture to get 30w? It comes off the last LNB
to give an arc of nearly 50.
The install menu on his STB has the following options
Switch no.1-4
LNB.F (set hi-lo I guess)
LNB.P- ON/OFF (Power on/off)
0/12 (set 0/12v)
Am I right in thinking a manual A-B switch would be reqd?
If there is a guide on this site perhaps you would be so kind as to post
the link.
Cheers.
Switch no.1-4
0/12 (set 0/12v)
the link.
Cheers.
