Taquilla Codes
Burnt Chips
Overclocker Supreme & General Mad B*st*rd
sunny manchester (i wish )
Just needed the address myself. By the way Grass-hopper
what sat is Private gold on. My funfiles states it will do it
But cannot find the bugger. DAVE.
Burnt Chips
Cheers old sat.
And its 24 hours a day
No peace for the wicked
Burnt Chips
Ive just tuned in eutell f11 and cannot find it.
BC has a Strong 4375, in which case he will have to add the transponder details manually and then perform a scan. The frequency is not within the standard table of frequencies
Burnt Chips
Thanks for advice Grass Hopper, I thought i was goind DAFT:
I tried a Sat tune and no Private gold. Did as you suggested
with Old Sats Frequencys and tp info and managed to tune it and a few more. If I`m right its in Irdeto 1 . Just hope its freecam freindly. as the 6 in 1 i have tried never worked. I think i`ll try a few different files. DAVE.
lee32uk
Technomate 1500ci+ super
Triax 1.1m dish
Diseqc motor
Invacom lnb
Manchester
Yes it is in Irdeto1.I usually find the best way to clear the channel is to switch the receiver off for a couple of seconds and then back on and it usually works.Make sure the dish motor is turned off so it stays on the same channel.
Lee
L
luap
Help please, i can now get Private Gold by doing the above stuff but it will not un scramble i have a 6 in 1 fun card and got the lastest codes from the normal places ie phillsfiles.com but to no luck...........can you help again, ta Paul:)
Burnt Chips
I had it on for about an hour on friday. I then found out it changes (DAILY) so youve gotta be quick proggin card.
So if you thought (Ticket) was a pain in the RRS every three days.This is the bigger paln.(haemeroids) Dont think its worth the shite (plus fargin your caRds proggln daily). DAVE.
Any wisearse about me spellin dont bother(aint got em so cannot spell em) THIS MEENS U . CH
I wouldnt rise to the occasion
Are you Mikeeys long lost cousin?
Try downloading Wordweb (about 4meg). Will save you a lot of bother and its useful to have on the desktop
Burnt Chips
How do you download.??????????????????????????????????????
HERE
Also you might find THIS Useful, its called Web Ferret, one of the best things I've ever downloaded, I believe CH is a proponent as well.
PRINCE
uh::
@ luap to get PG you need to switch your receiver on and off
a few times before the channel would clear.You also need to be aware of what burntchips said about constant code change.
regards
Prince
Burnt Chips
It wass a joake bouys
LOL.....You sure mate. :D
Burnt Chips
LOL ! Ive just sussed out why me 6in1 files (fun card4) not been working. I didn`t Know you had to download it.
( I thought if you seen the files on the screen it autoupdated your card) BUMMER so that why i can only watch the FTA channels.)
PS jokeing apart : i actually know somone who thought that.
DAVE.
Aistys
and what does it makes that spanich forum nothing new we have and who knows when we will get again PALCOS and others????
